M2 Internship – February 2027
Automatic Generation of SOFA Documentation and Interactive Assistance from Source Code and Scientific Literature Using AI
Context and Motivation
The SOFA (Simulation Open Framework Architecture) framework is a powerful open-source platform for real-time physics-based simulation, used in fields such as soft robotics, biomechanics, and medical simulation. Its flexibility and modular architecture allow advanced modeling, but this richness also introduces a steep learning curve for new users and developers.
To facilitate its use, SOFA developers provide documentation, tutorials, and scientific publications. However, these resources are:
- Distributed across code, documentation websites, and research papers.
- Difficult to keep synchronized with rapid code evolution.
- Often too technical or fragmented for newcomers.
As SOFA continues to grow, there is a strong need for automated, up-to-date, and intelligible documentation, as well as interactive tools that help users understand how code, theory, and simulation concepts relate to each other.
Recent advances in Artificial Intelligence, particularly Large Language Models (LLM)s and code understanding systems, open new opportunities to automatically extract knowledge from source code and scientific literature, and to present it in human-readable and interactive forms.
Objectives
The main objective of this internship is to design and prototype an AI-based tool capable of generating structured SOFA documentation from existing sources, including:
- SOFA C++ source code and scene descriptions [1]
- Existing SOFA documentation
- Scientific articles and publications related to SOFA
A secondary but closely related objective is to explore the feasibility of an interactive chatbot that can answer user questions about SOFA by leveraging the same knowledge base.
Scientific and Technical Goals
The internship will focus on the following goals:
Automatic Documentation Generation
- Extract high-level concepts from SOFA source code (components [2], solvers, etc…).
- Generate human-readable documentation describing:
• Component purpose and usage
• Relationships between modules
• Links between theoretical models and implementation details
Knowledge Integration
- Align information extracted from code with:
• Official SOFA documentation
• Scientific publications explaining underlying physical and numerical models
- Build a coherent, structured knowledge representation.
AI-Assisted Question Answering
- Prototype a chatbot capable of answering questions such as:
• “What is the role of this SOFA component?”
• “Which solver is appropriate for this type of simulation?”
• “How does this implementation relate to the theory described in a given paper?”
Exploration of automatic simulation scene generation
- Investigate the feasibility of automatically generating simple SOFA simulation scenes from existing components, in particular using pre-fabs, in order to illustrate documented concepts and facilitate experimentation.
Methodology
The internship will be organized into several phases:
State of the Art and Familiarization
- Study the SOFA framework architecture (scene graph, components, solvers).
- Review existing SOFA documentation and tutorials.
- Analyze relevant scientific literature related to SOFA and real-time soft-body simulation.
- Survey AI techniques for:
• Code analysis and summarization
• Documentation generation
• Retrieval-augmented generation (RAG)
Knowledge Extraction
- Develop scripts or pipelines to extract:
• Structural information from SOFA source code (classes, inheritance, templates, dependencies)
• Semantic information from comments, naming conventions, and documentation
- Identify links between code elements and scientific concepts.
AI-Based Documentation Generation
- Use or fine-tune language models to:
• Generate structured documentation (markdown, web-ready formats)
• Produce explanations adapted to different levels (beginner / advanced)
- Evaluate documentation quality in terms of accuracy, clarity, and usefulness.
Chatbot Prototype
- Build a chatbot interface backed by:
• The generated documentation
• Code-level knowledge
• Relevant publications
- Implement query handling and context retrieval to answer SOFA-related questions.
Validation and Case Studies
- Test the tool on selected SOFA modules or plugins.
- Compare AI-generated documentation with existing human-written documentation.
- Gather feedback from SOFA users or developers if possible.
Expected Outcomes
By the end of the internship, the following outcomes are expected:
- A working prototype capable of generating documentation from SOFA code and related texts.
- A proof-of-concept chatbot for assisting SOFA users.
- A structured knowledge base linking: (1) Code, (2) Documentation, and (3) Scientific theory.
- A technical report describing: (1) Methodology, (2) Design choices, and (3) Limitations and future improvements.
Candidate Profile
Programming: C++, Python
AI & NLP: Large language models, embeddings, retrieval-augmented generation
Scientific Computing: Numerical simulation, physics-based modeling (desired)
Starting Date and Allowance
The internship start date is expected to be around beginning of February.
The internship will be compensated according to the standard remuneration in force for M2 internships in French public research institutions (about 600€).
Application
If interested, please send your resume to zeinab.awada@inria.fr.
Find more about SOFA and the DEFROST team at:
https://sofa-framework.github.io/doc/
https://www.defrost.inria.fr/
[1] In the SOFA framework, a scene is a structured description of a simulation setup, including the simulated objects, their physical properties, and the numerical methods used to compute their behavior.
[2] Component corresponds to C++ classes implementing specific physical models or algorithms.
Stage M2 – Février 2027
Génération automatique de documentation SOFA et assistance interactive à partir du code source et de la littérature scientifique à l’aide de l’IA
Contexte et motivation
Le framework SOFA (Simulation Open Framework Architecture) est une plateforme open source puissante dédiée à la simulation physique temps réel, utilisée dans des domaines tels que la robotique molle, la biomécanique et la simulation médicale. Sa flexibilité et son architecture modulaire permettent des modélisations avancées, mais cette richesse s’accompagne également d’une courbe d’apprentissage élevée pour les nouveaux utilisateurs et développeurs.
Afin de faciliter son utilisation, les développeurs de SOFA mettent à disposition de la documentation, des tutoriels et des publications scientifiques. Cependant, ces ressources sont :
- Réparties entre le code, les sites de documentation et les articles de recherche.
- Difficiles à maintenir synchronisées avec l’évolution rapide du code.
- Souvent trop techniques ou fragmentées pour les nouveaux arrivants.
À mesure que SOFA continue de se développer, il existe un besoin fort de documentation automatisée, à jour et intelligible, ainsi que d’outils interactifs permettant aux utilisateurs de comprendre les liens entre le code, la théorie et les concepts de simulation.
Les avancées récentes en intelligence artificielle, en particulier les grands modèles de langage (LLM) et les systèmes de compréhension de code, ouvrent de nouvelles perspectives pour extraire automatiquement des connaissances à partir du code source et de la littérature scientifique, et les présenter sous des formes lisibles et interactives.
Objectifs
L’objectif principal de ce stage est de concevoir et de prototyper un outil basé sur l’IA capable de générer une documentation structurée de SOFA à partir de sources existantes, notamment :
- Le code source C++ de SOFA et les descriptions de scènes [1]
- La documentation existante de SOFA
- Les articles et publications scientifiques liés à SOFA
Un objectif secondaire, mais étroitement lié, est d’explorer la faisabilité d’un chatbot interactif capable de répondre aux questions des utilisateurs sur SOFA en s’appuyant sur la même base de connaissances.
Objectifs scientifiques et techniques
Le stage se concentrera sur les objectifs suivants :
- Extraire des concepts de haut niveau à partir du code source de SOFA (composants, solveurs, etc.).
- Générer une documentation lisible par l’humain décrivant :
• Le rôle et l’utilisation des composants
• Les relations entre les modules
• Les liens entre les modèles théoriques et les détails d’implémentation
Intégration des connaissances
- Aligner les informations extraites du code avec :
• La documentation officielle de SOFA
• Les publications scientifiques expliquant les modèles physiques et numériques sous-jacents
- Construire une représentation cohérente et structurée des connaissances.
Question-réponse assistée par l’IA
- Prototyper un chatbot capable de répondre à des questions telles que :
• “Quel est le rôle de ce composant SOFA ?”
• “Quel solveur est approprié pour ce type de simulation ?”
• “Comment cette implémentation se relie-t-elle à la théorie décrite dans un article donné ?”
Exploration de la génération automatique de scènes de simulation
- Étudier la possibilité de générer automatiquement des scènes SOFA simples à partir de composants existants, notamment via l’utilisation de pré-fabs, afin d’illustrer les concepts documentés et faciliter l’expérimentation.
Méthodologie
Le stage sera organisé en plusieurs phases :
État de l’art et prise en main
- Étude de l’architecture du framework SOFA (graphe de scènes, composants, solveurs).
- Analyse de la documentation et des tutoriels existants de SOFA.
- Analyse de la littérature scientifique pertinente liée à SOFA et à la simulation temps réel de corps déformables.
- Revue des techniques d’IA pour :
• L’analyse et la synthèse de code
• La génération de documentation
• La génération augmentée par la recherche d’information (RAG)
Extraction de connaissances
- Développer des scripts ou des pipelines pour extraire :
• Des informations structurelles du code source de SOFA (classes, héritage, templates, dépendances)
• Des informations sémantiques issues des commentaires, conventions de nommage et de la documentation
- Identifier les liens entre les éléments du code et les concepts scientifiques.
Génération de documentation basée sur l’IA
- Utiliser ou affiner des modèles de langage afin de :
• Générer une documentation structurée (markdown, formats web)
• Produire des explications adaptées à différents niveaux (débutant / avancé)
- Évaluer la qualité de la documentation en termes de précision, clarté et utilité.
Prototype de chatbot
- Construire une interface de chatbot reposant sur :
• La documentation générée
• Les connaissances au niveau du code
• Les publications scientifiques pertinentes
- Implémenter la gestion des requêtes et la récupération de contexte pour répondre aux questions liées à SOFA.
Validation et études de cas
- Tester l’outil sur des modules ou plugins SOFA sélectionnés.
- Comparer la documentation générée par l’IA avec la documentation existante rédigée par des humains.
- Recueillir des retours d’utilisateurs ou de développeurs SOFA si possible.
Résultats attendus
À l’issue du stage, les résultats suivants sont attendus :
- Un prototype fonctionnel capable de générer de la documentation à partir du code SOFA et de textes associés.
- Un chatbot preuve de concept pour assister les utilisateurs de SOFA.
- Une base de connaissances structurée reliant : (1) le code, (2) la documentation et (3) la théorie scientifique.
- Un rapport technique décrivant : (1) la méthodologie, (2) les choix de conception et (3) les limites et perspectives d’amélioration.
Profil recherché
Programmation : C++, Python
IA & TAL : grands modèles de langage, embeddings, génération augmentée par la recherche
Calcul scientifique : simulation numérique, modélisation physique (souhaité)
Date de début et gratification
La date de début du stage est prévue aux alentours du début février.
Le stage sera indemnisé conformément à la gratification en vigueur pour les stages de M2 dans les établissements publics de recherche français (autour de 600€).
Candidature
Si vous êtes intéressé(e), veuillez envoyer votre CV à zeinab.awada@inria.fr.
Pour en savoir plus sur SOFA et l’équipe DEFROST :
[1] Dans le framework SOFA, une scène est une description structurée d’un environnement de simulation, incluant les objets simulés, leurs propriétés physiques et les méthodes numériques utilisées pour calculer leur comportement.
[2] Un composant correspond à une classe C++ implémentant un modèle physique ou un algorithme spécifique.
