Master 2 Internship Proposal
Unified Modeling of Cable-Driven Robotic Endoscopes Based on Cosserat Theory
Supervisors: Y. Adagolodjo, J. Dequidt, H. Courtecuisse
Duration: 6 months
Context
Flexible robotic endoscopes represent a major advancement in minimally invasive surgery, enabling access to difficult-to-reach anatomical areas while minimizing patient trauma. These complex devices consist of several critical components: an outer sheath, actuation cables, internal channels, and imaging systems.
Currently, endoscope modeling relies on segmented approaches where each component is treated independently, limiting simulation accuracy and complicating integration for real-time control. The ANR project in which this internship takes place aims to develop a unified modeling framework to represent the endoscope as a single flexible body actuated by cables, thereby simplifying simulation while maintaining high accuracy.
Internship Objectives
The main objective of this internship is to develop a unified hybrid model for a flexible robotic endoscope using Cosserat theory. Specifically, the intern will:
- Master Cosserat theory: Understand the mathematical foundations of Cosserat theory and its application to flexible structure modeling, particularly its ability to describe coupled deformations (bending, stretching, twisting, shearing).
 - Reformulate equations of motion: Adapt the traditional Cosserat formulation (material space) to a generalized Cartesian coordinate system. This reformulation aims to maintain the efficiency of stiffness matrix computation while overcoming mass matrix limitations for real-time dynamic simulations.
 - Develop a unified model: Implement an integrated endoscope model that captures its nonlinear mechanical response and complex deformations during interaction with soft tissues, while considering cable actuation.
 - Validation and simulation: Implement the model in the SOFA framework (open-source) and validate its performance in terms of accuracy and computation time for real-time simulation applications.
Scientific Challenges
- Mathematical reformulation: Transform Cosserat equations from material space to a generalized Cartesian system while preserving essential mechanical properties.
 - Computational efficiency: Ensure that the developed model is fast enough for real-time simulation applications, particularly for robotic control.
 - Numerical stability: Ensure model stability under large nonlinear deformations, typical of endoscope-tissue interactions.
 - Actuation integration: Correctly model cable actuation within the unified Cosserat framework.
Required Skills
- Strong background in continuum mechanics and numerical computation
 - Proficiency in programming (C++, Python)
 - Knowledge of numerical methods (finite elements, time integration)
 - Interest in medical robotics and physical simulation
 - Autonomy and ability to work on complex problems
 - (Optional) Experience with simulation frameworks (SOFA, or similar)
Expected Work
- Months 1-2: Comprehensive literature review on Cosserat theory, flexible endoscope models, and familiarization with the SOFA framework.
 - Months 2-3: Theoretical development of Cosserat equations reformulation in generalized Cartesian coordinates.
 - Months 3-5: Model implementation in SOFA, cable actuation integration, and validation tests.
 - Months 5-6: Performance optimization, comparative validation with existing models, internship report writing, and scientific paper contributions.
Deliverables
- Source code of the model implemented in SOFA (open-source plugin)
 - Detailed internship report with theoretical analysis and experimental results
 - Technical documentation for code reuse
 - Contribution to a scientific publication on the obtained results
Work Environment
The internship will take place within a research team working on medical robotics and real-time simulation. The intern will benefit from:
- Close scientific supervision
 - Access to computational infrastructure and laboratory equipment
 - Integration into an ANR project with national collaborations
 - Opportunity to present work at scientific conferences
Perspectives
This internship can lead to a PhD thesis within the ANR project framework, with prospects for publications in leading international conferences and journals in medical robotics and numerical simulation.
Key References
- Adagolodjo, Y., Renda, F., & Duriez, C. (2021). “Coupling Numerical Deformable Models in Global and Reduced Coordinates for the Simulation of the Direct and the Inverse Kinematics of Soft Robots.” IEEE Robotics and Automation Letters, 6(2), 3910-3917. doi: 10.1109/LRA.2021.3061977
 - Ouyoucef, A., Peyron, Q., Zheng, G., & Boyer, F. (2025). “Modeling, analysis and design of an extensible planar parallel tendon actuated continuum robot.” 2025 IEEE 8th International Conference on Soft Robotics (RoboSoft), Lausanne, Switzerland, pp. 1-8. doi: 10.1109/RoboSoft63089.2025.11020851
Application
Interested candidates should send:
- Detailed CV
 - Cover letter
 - Master’s transcripts (M1 and M2 if available)
 - Letter of recommendation (optional)
Contact: yinoussa.adagolodjo@inria.fr, jeremie.dequidt@inria.fr
