Master 2 Internship – Starting February 2027
SOFA is an open-source platform used for real-time physics simulations in fields like soft robotics, biomechanics, and medical research. While it’s already powerful, simulating complex behaviors—such as large deformations, nonlinear materials, or plasticity—remains a major challenge.
This internship aims to improve SOFA by implementing advanced material models and numerical solvers, making it easier to simulate realistic soft tissues and other complex systems.
What You’ll Work On
Your goal will be to enhance SOFA’s capabilities by turning cutting-edge theoretical models (like plasticity or hyperelasticity) into practical, efficient C++ code. Specifically, you’ll focus on:
1. Embedded Element Hyperelasticity
– Review advanced methods for embedding elements in hyperelastic materials.
– Develop a flexible framework to integrate these elements into SOFA’s simulation system.
2. Element-Agnostic Material Models
– Identify limitations in SOFA’s current material models.
– Adapt models (e.g., plasticity, viscoelasticity) to work seamlessly across different element types.
3. Robust Incompressibility Constraints
– Research stabilization techniques for near-incompressible materials.
– Implement a solution that works reliably across different mesh types.
4. Advanced Plasticity Framework
– Review existing plasticity models in SOFA.
– Develop a generalized plasticity solver and integrate it into SOFA’s core.
How You’ll Work
The internship is structured in four phases:
1. Research & Design
– Study advanced continuum mechanics theory.
– Analyze SOFA’s architecture to determine where new solvers should fit.
2. Mathematical Framework & Prototyping
– Derive equations and numerical models for the new features.
– Test prototypes in a controlled environment before integrating them into SOFA.
3. Core Integration
– Write clean, optimized C++ code following best practices.
– Integrate new solvers into SOFA’s simulation pipeline.
4. Validation & Documentation
– Create test cases to verify accuracy and stability.
– Write clear documentation explaining the math, implementation, and usage.
What You’ll Deliver
By the end of the internship, you’ll have:
– Code contributions: Pull requests to SOFA’s repository, adding support for embedded hyperelasticity and at least two element-agnostic material models (e.g., viscoelasticity and plasticity).
– Technical documentation: Detailed explanations of the math and implementation for each new feature.
– Demonstrations: Working examples showcasing the new capabilities.
– Final report: A summary of your methodology, challenges, and future directions.
Who We’re Looking For
– Strong C++ skills (mandatory).
– Solid background in math: Continuum mechanics, nonlinear solid mechanics, or computational physics. Knowledge of differential geometry or numerical methods (e.g., finite element analysis) is a plus.
– Research mindset: Ability to review complex scientific literature and turn theory into robust code.
Practical Details
– Start date: Early February 2027.
– Compensation: Standard M2 internship salary in French public research (~600€/month).
– How to apply: Send your resume and a cover letter explaining your experience in computational mechanics to alexandre.bilger@inria.fr.
